E9 parts FS: Lowering springs, starter motor, engine mounts, various etc.
CallumNicklin
Brighton, UK
Hi all,
Various parts left over from recent works. Located in Brighton, UK.
Jaymic front lowering springs. Driven for ~100km, fitted for about 6 months. £70. Small bit of surface rust at one end of one spring.
Nr 0001311042 Starter motor from 635csi. Works, but possibly faulty. Removed when our car had some intermittent starting issues. Can't remember if it was the starter or otherwise. £30 + postage.
80d thermostat. Used. Fitted a lower temperature version. £Donate to forum + postage.
Engine mount x 2. Used but OK. £10 for pair + postage.
ITB gaskets x 12. Custom made when experimenting with ITBs. £Donate to forum + postage.
Various wires and crimps for ECU wiring. New. £Donate to forum + postage.
Green button insert. Used. £Donate to forum + postage.
Hella 304126082 LHD lamp lens pair. Used. I believe these are originally for an E21? Anyway they came off the E9 that I bought in Hamburg. £50 + postage.
Coolant passage. Used. £40 + postage.
Jenvey throttle linkage parts: CLS1 kit with LBU1 mounting bracket. Fitted in situ then removed when changing ITB setup. £SOLD.
Brown Ashtray. Chrome has lost some shine but OK. £SOLD.
CSL Sunvisor clips. New. £SOLD.
Alpina hub caps x4. 2 are better than others. Used. £SOLD.
MOMO steering wheel hub. Used. £SOLD.
Cheers,
Cal.
hello Cal I would like to buy the springs
Gr Hans
Hi Cal, I would like the CSL visor clips and the steering hub if still available?
Adam
