WTB: manual swap clutch and brake pedals
I believe the pedals for the 2000CS are the same and I do have them. I hope your talking about the metal pedal and not the rubber.
Yes, I am looking for the actual pedals.
How much would you like for them?
Looking for #1 and 2
Made my own out of a an e32 brake pedal… it looks okay for a start.
Hey wondering did you keep the auto e9 brake pedal and just cut it ,and use an e32 brake pedal for the clutch one ?
Yes, i cut the automatic brake pedal pad shorter and modified an e32 brake pedal for the clutch
Ok thanks , question if you had two automatic e9 pedals would you attempt to use an e9 auto brake pedal for the clutch ?
Did the e32 brake pedal need any modifications at the top mounting bolt , and connecting it to the clutch master how was that
I had to cut it shorter but the ID of the bushing is exactly the same. However, the clutch pedal ended up shifted about 1inch to the left. I drilled and tapped the pedal for an M8 bolt (pedal is at least 1/4 thick) to connect the clutch master.
Note: I am using a cheap master cylinder from an e23 but I have not verified that it will work… it does however bolt up to the pedal box with no issues.
If interested, i can post more pics of the setup.
This was my only reference to fabricate my own. I found it somewhere on this forum.
The clutch master is the same for e3, e9, e12, e23, e24…..
  • Like
Reactions: Ezz
I checked with realoem for e3, e23, and e32 and the cylinder diameter listed for them is the same, 19.05mm
Also, the same diameter for the slave cylinder 22.20mm
I will be using a slave cylinder from the e32
