For the record the stock zenith gets advance vacuum from the right front corner of the frontcarb above the throttle plate, retard was hooked to rear carb on driver side under the throttle plate with manifold vacuum.
			Yes. But not directly to the fuel tank. That pipe goes to the plastic accumulator container on the right side of the trunk between the wheel well. and the fender. From there to the tank. If you had this hose hooked up correctly and the other hose coming out of the charcoal canister hooked to the intake manifold vacuum port, that would account for the "whooshing" sound when you opened the gas cap. It was trying to create a vacuum in the tank and at some point would have probably stopped fuel flow to the carbs.Hello to all, To Dick Stienkamp, On the charcoal canister question, So the two pipes from canister, one goes to the fuel tank and the other one goes to the fitting under the air filter housing? OK, I can correct that.
Correct...as long as you mean charcoal CANISTER and not vacuum advance CANISTER.Hello all, As I explained in the beginning, The vacuum hose to the canister from what I thought a welded up fitting on the intake was capped off with a golf tee. I fixed the welded up fitting and attached a new hose to my new port. Dick says this wrong it should go to a fitting on the under side of the air filter housing. I will correct that tomorrow.
