Front grille screws
chope97
Silver Spring, MD
I have two running e3 and a parts car and I still don't know what screews I should buy to properly mount the grilles to the cars. Is there a screw I can get from HomeDepot that will work? or some other source? Thanks in advance
Yes, size 10 Stainless Phillips Pan Head 3/4 inch or 2cm long. Be sure all the automotive flat speed-nuts are clipped in the slots behind the grills.
Home Depot, Lowe's, Ace True Value.
If you also don't have any of the speedclips, the hardware store should have those also. Just make sure they match up with the screws you select.
Here are the BMW PNs for the screws and clips and the generic OE screw and clip sizes. As Chris advises, be sure to get black screws.
