hello I own a 1971, BMW 3,0 CS
the carburetors version, mounting 2 zeniths
I am worried because I think that the temperature of the cooling liquid is excessive, in this photo you see the normal position of my temperature gauge while driving in 4th gear at 80km/h in a flat road with outside temperature of 12 ºC
when I stop the car the gauge goes up even, but not entering the red zone never
I made an important restoration of the cooling system one month ago:
- clean the circuit
- new tubes
- new water pump
- new radiator
- new fan and visco clutch
- new bosch sparks
- new thermostat
- new temperature sensor
- new cooling liquid, complete bleeding of the system
there is also a fact that is: when the engine is hot, if I stop the car, and few minutes later I start it again, the temperature goes down until the gauge is below the middle of the scale for a few seconds
(I may think that this means a sudden and big opening of the thermostat), the question is why this is not happening normally
do you think this level of temperature is normal running condition ?
regards and thank you for helping
- clean the circuit
- new tubes
- new water pump
- new radiator
- new bosch sparks
- new thermostat
