It's all about your current differential type - early vs. later.WN list this as good for 2800cs & CSA. I can't be sure it's also good for a 3.0cs.
Only because 3.45 was standard on 2800WN list this as good for 2800cs & CSA. I can't be sure it's also good for a 3.0cs.
Just buy new?
Crown gear set 38:11 ratio 3.45:1 with M10 thread for crown gear fastening for 2800 CS and 3.0 CS up to 1971 you need 1 for 1 car
Crown gear set 38:11 ratio 3.45:1 with M10 thread for crown gear fastening for 2800 CS and 3.0 CS up to 1971 you need 1 for 1 carwww.wallothnesch.com
This Jon, turned out to be the correct answer as I can confirm and experienced first hand. We used the earlier M10 crown gear in our later differential using larger bolts. Both had eight bolts.No, because the WN crown gear has "M10 holes" for earlier 2800 models.
The 3.0 models use M12 crown gear bolts.
How did you use "larger bolts" with the M10 crown gear?This Jon, turned out to be the correct answer as I can confirm and experienced first hand.
