Air filter needed
chope97
Silver Spring, MD
I need to replace my junk pink airlfilters, I had some K&N washable filters but for some reason I can only find one in my trunk what other air filter will fit from a different car that K&N still may make the e-2850 for 2002 and e3 seems to be no longer available
you can use Mann, knex , bosch,
kn is overrated
chope97
Silver Spring, MD
If you can blow up the picture you will see that the pink plastic is flowing over the filter element very inconsistently. I think I got these off of ebay
lip277
Seattle
It has been a long time since I bought a filter for the carb'd 2.8L motor that was in my E9.
(I have an EFI system now, so it uses the same filter as my E23).
I have had good luck with Hengst, Mahle and WIX.
I have used MANN in the past (for other cars) and found them ok.
YMMV as always....
Luis A.
Wisconsin
The air filters I last purchased from BMW were the pink ones and had the same 'overflow' of rubber. I trimmed all of it off with an Xacto knife.
