E3 Strut Mounts
StephenZ
Cumming, GA
Do the strut mounts for the E3 crossover with other models? Are genuine that much better than aftermarket, or is it just the BMW tax? Thanks.
Stephen,
the struts on the e3 and e9 are the same. this also applies to the upper mount. i presume you are talking about the bearing that shows up under the hood that holds the top of the strut. they are only 118 bucks (ea) from getbmwparts.com
i am not sure what is different between the part that Mike has referenced versus the one that i did ... except the price (3x). they both seem to be the same part with some minor difference ... and both are for e3 and e9. the xx663 part is also applicable for the e12 and e24
i have learned that the e12 strut mount is the same but has short studs (and were cheaper). @StephenZ, if you are in need of a refurbed set of strut mounts, start a conversation with @HB Chris ... i believe he has a spare set
