Need 3.0 CS trailing arms
halboyles
KC
The rear drum assemblies on our '71 2800 CS are in very bad shape and, rather than spend money on replacing all the drum parts, I'd rather find some 3.0 CS trailing arms to use the caliper/rotor system. Does anyone have a set available?
On FB:
Thanks for the link @teahead. It appears that the posting has already been pulled, so the search continues.
I have the e3 (1971 2800A bavaria) trailing arms for caliper setup.
Are those arms a bolt-on replacement for the drum brake arms on the 2800 CS?
RealOEM says no. But could be because of drum vs disk setup?
So I am not sure and differ the answer to those who have knowledge
It was discussed on that forum that trailing arms differs between E3 and E9 as the rear subframe.
AFAIK only front frame with suspension is exchangeable between theses similar model.
Seems like such a waste to tear up such a nice looking stock E9.
Also, be careful of scams.
Tell him to list it on Ebay if he has an ebay store on there.
