2000 CS wiper motor wanted
One is on the Kleinanzeigen in parts.
Second was parted out by #Strefarekinow on fb probably.
There is also "CarsByLinke" - expecting them to be able to contact them on fb as well.
None of the sellers are known to me. So it is hard for me to provide any more details.
Not sure it is helpful. Let me know if you need any help.
I'm pretty sure it would be more cost efficient to look for the part in US and looking abroad later.
Thank you very much.
i looked to see if it was a different motor than the 2800cs / 3.0cs or the 2002 and it is. no idea if the 3.0cs assembly would fit into the 2000cs. can you post a pic of the assembly in the car? also, what is the measurement between the wiper arm posts? this is just a curiosity thing.
I thought 2002 might fit as well but apparently not
got it ... my thought was to see a pic of the actual car and to know what the dimension is from post to post. finding a working motor from a 2000cs might not be easy ... but if the dimension from post to post was approx 20 3/16" then the e9 coupe part might fit. those parts aren't that hard to get.
Between the posts the measurment is the same. I wonder what fabrication I would need to make such as a bracket to hold the E9 assembly. But what I could see from the E9 is that the motor is mounted in the middle and would interfere with the 2000 CS fan motor. Also, the 2000 CS motor has only 2 terminals. Thanks again.
Thanks again.
the 3.0cs motor is NOT in the center, it on the drivers side of center. the blower / intake is in the center.
