Guibo re install
Barry.b
Ireland
Hi guys
I recently fitted a brand new guibo
It came supplied with a metal band around it holding it in shape.
Once installed I removed the metal band and all was well.
Unfortunately I have to remove my driveshaft again so I am just wondering is it possible to reuse that same new guibo again when I put everything back together ?
- it no longer has that metal band around it
Hi guys
my thoughts,
I wonder if you only remove three bolts you might be able to reuse it
also you can try that clamps for hoses that come in a continuous long stripe and then you cut to size
you will use a big prybar to compress one bolt hole surround at a time if you want quick and dirty or use a big hose clamp if you want fancy.
I had thought you could remove the drive shaft bolts as long as the tranny flange bolts remained in place.
Okay
Sounds good
It would be a waste of a brand new part otherwise
Thanks again for the advice !
