Boot Badge
Wobdog
a.k.a Mike
Los Altos Ca
What is correct part for boot badge. I took of my existing badge and it has part number 51141872327 on the back of it. Walloth shows part A51141872328 as correct part. They have both and I do know that 51141872327 works since that was what was on my car. Anyone have more info
Mike
there are 2 badges - one is a flat badge that fits on a base, the other is a one piece with a shaped bottom to fit onto the trunk
the original ones were 2 piece - so if you were building a concours car, then you probably want a 2 piece. i will tell you that some of the flat badges are a little bigger (maybe 1mm or 2) in diameter than the base ... not the perfect match they originally were. i have a one piece ...
Candia4441
California
I have the 2 piece badge, do you have any parts to traid.
I have the one piece now. Any advantage of one over the other?
Always I mess up boot and bonnet and hood,...
To the Best of my knowledge front and rear are a two piece, same emblem raised letters alu, plus a chromed base, straight base at front and shaped base rear
They look a bit better and they are the original thing,
If you dont care much, you probably can live with the one piece ones if at least they are raised letters alu
Mike
some images
the three part system in boot, support shaped curved as to sheet metal
this is the front: in this case it is a one piece only, not the supercorrectone
