My 1973 E9 (US, standard transmission, Weber conv.) has an intermittent starting issue. About 1 time out of 10, I will turn ignition key to engage starter, and nothing happens. No fuel pump, lights on dash etc. I turn the key to the off position, try it again and car starts as per usual.
A few years ago, I replaced the ignition wires (or the wires leading to the back of the ignition switch inside the steering column, and this seemed to postpone the problem. It seems now that the problem is happening more often, maybe one time in 5. It does usually correct itself, but I really don't want to get stranded as I venture outside my usual 20 mi radius.
Also, the infamous grub screw appears to be absent, so what exactly is holding the ignition cylinder in place??
Any hints or suggestions would be greatly appreciated.
