WTB: Interior and exterior aluminum trim in perfect condition
CharlesJ
Arlington, VA
About to restore all my trim, but before going down that path, wanted to see if anyone has either near perfect original parts or restored parts. These are going on a fully restored vehicle, so would need to be in great shape. I am aware there are also new parts out there for some of this, but wanted to check here first. Need everything that is shiny aluminum except the following: front grills, emblems, rain rail, center console trim, and dash trim.
BMW - Bring Your Wallet. What ever you can find NOS is going to cost you a small fortune. You could look into getting your belt line trim, sunroof pieces (if needed), interior door strips, etc... stripped and polished locally - might save you quite a bit.
Yeah, I have looked into all options and they are varying degrees of bad/expensive. Has to be done, so just a matter of which option is least bad. Polishing/coating is my current best bet for most parts, but a little challenging and still quite costly as I do not have the time to do it myself. At least if I buy something else, I have decent condition parts to sell to offset the cost as most of my parts are good, just not to the finish level I need. I also know I need the front and rear window trim as those are missing, and even the W&N cost is tough to swallow
For the aluminum trim on the outside of the car; Speedway Metal Polishing in Santa Ana CA. Excellent work and much less expensive than the reproduction BMW trim that doesn't fit.
Just connecting: There is a full external trim set available through GermanyExclusive, e9 expert here in NL.
Mind you, BMW sold alu waist trim parts in the ~2010 era that fitted badly. No knowledge if what is available here has that dilemma.
Yeah, I have been hesitant to buy any new beltline trim for that reason including the W&N ones. I actually have a NOS front trim piece, but can really only use that if I find all the perfectly matched anodizing trim to go with it that actually fits.
That was actually my first option. I emailed Dan and they no longer do the polishing part, which means taking it to two different places and sending it around after it has been polished. Have a backup option for that locally, but it comes out pretty pricey as well.
