Wtb
Peter Coomaraswamy
Austin, TX
Does anyone have the L&R side plastic pieces that go under the rear outer window chrome trim that attaches to the body and then to the trim its self. I do not know the name of the pieces.
Please PM me -
Hello,
I think I may have described what I am looking for incorrectly. I is the thin plastic trim the runs from the front to the back of the lower rear window trim. I have attached a picture to show. IF anyone knows where I can source this it would be greatly appreciated.
Cheers-Ted
Holy resurrection Batman! This thread is more than ten years old.
I think Walloch Ness sells this stuff:
Nop, that seal is at the bottom of the door, sealing the bottom from water coming in from below.
I think @Ted D. Is looking for the black pvc type U shaped channel that is keeping the chrome trim next to the glass from touching the paint.
I think it is identical material as the profiles used on the stainless steel wheel arch trims.
this one? I’ve heard…..that the new production is not the same quality!
This is a simple piece of trim/gasket and I am gonna bet you can find it on the Steele Rubber Products website for cheap money.
This is what I have (but likely need for my own 4 wheel trim and door parts)
It is a U shape, its 2.6 mm wide
but one side is 5,0 mm, while the other side is 6,0mm. Each flap is 1,0 mm thick.
