Sheet metal Bmw e9
bavarian
Hey I chopped up an e9 and I have some left overs
Main sheet metal I’m selling that I think is most desired. I can cut out any seat mounts
Rocker each side l 100$ plus shipping
Rear window bottom seal area sheet metal 100$ plus shipping
Taillight panel ( not the entire thing just the strip )100$ plus shipping
Rear diff mount 100$ plus shipping
Most of the stuff has surface rust but some areas are fully usable if your not planning on replacing the full panels
Was wondering are the rear hubs with drum brakes the same as the rear hubs with disc brakes??
Also I have rear drum brake parts available including the hydraulic cylinder
The rear training arms are different, having (no) mounting provision for the calipers.
Drum brake setup isn't that desirable unfortunately.
yes i was wondering if the hubs themselves are the same from disc to drum even though control arms are different
Realoem.com, or a paper parts book, will also give you that information, as you can graphically go through the " drumbrake" car, find the partnumber of the component you are interested in, and then check on which models it was used.
