Trans rebuilder wanted
nealf
Gladwyne, PA
Hi I have a 5 speed Getrag 265 that I had removed and replaced with another last year due to nobody in my area that could rebuild the bad one. Is there anyone around that still does this? I am outside of Philadelphia, PA and was surprised to learn that there is nobody local. There was one guy, but he hurt his back and supposedly does not any longer.
I hate to see the one I have go to waste. I would rather have it rebuilt and get it into the hands of someone looking to do a 5 speed conversion.
Thanks!
Don has a shop that can open them, there is the issue of the NLA bearing that makes opening them less interesting.
I believe I have the NLA bearing. I bought from @eriknetherlands a few years ago on the chance I might need it, but don't as the transmission I sourced is in amazing low mileage condition and operating perfectly. It is available for sale.
My issue is Jammed or broken shifter forks. Would that require the bearing you all refer to?
Probably not, bad bearing symptom is grinding regular noise when transmission is in idle that goes away pressing the clutch.
Don covered it pretty thoroughly: 265/5 "dogleg" vs 265/6 OD
Different bearing, first gettable, second scroungeable at great cost.
Input bearing size on the 262 four speed on link is the layshaft bearing size on 265
But which is the one on Walloth is it the dogleg or the OD?
position 1
The link you provided is to the 4 speed box
23/24 is the 5 speed OD box; position 1 is the input bearing, noticeable in its absence from the listings
23/29 is the 5 speed dogleg box; position 12 is the input bearing, which they show
Is the box shiftable at every change? or if it's a dogleg? I ask because the dogleg in my 635 won't let me down shift into first unless I have really slowed down It pretty much locks me out till I reach a speed. it likes. It does upshift in all gears with no problems. Unless I am being "playful", I just mostly use 2.3.4.& 5th I Am also using a home made short shifter. I replaced the input and output bearing. I bought the output bearing at a bearing supply shop for a lot less than BMW but I did have to get the front from BMW. IIRC the front one has a snapping on it? If it doesn't I am wrong and got the bearing from the bearing house as well. It's been 15 years from when I started my journey and a lot of things I bought are now forgotten I have even found trim parts for my car where I have bought 2-3 extras
Trying to revive this thread and revive a 5 speed trans that needs rebuilding preferrably the closer to Philadelphia, PA the better. Thanks,
