FS:SOLD - Right Taillight Lenses and Bezel Set
Jim Stone
St Leonard, Md
A spare right lens assy that needs a new home. Conditions are as follows:
- chrome bezel has corrosion so in fair condition; I would re-chrome it
- the installed red lens has a through crack ( not usable) the two other red lenses are in good shape but do have minor internal cracks while structurally intact and could use a good polishing
-the two backup light lens (amber and clear) are structurally intact and in good condition but could use a good polishing
-and the two amber turn signal lens (R/L) are structurally sound in good condition with one that has minor scratches while the other none.
There are 2 of 4 threaded fastener in the reverse side of bezel.
Additional photos upon request. Thanks!
$150 OBO plus shipping
Mariusz, thanks for asking.
I’m willing to sell you the frame with the installed/glued in lenses for $75. I don’t feel I can safely remove the two although the red lens is cracked.
Do you have an US address? Thinking shipping charges to Poland from Maryland may be steep.
Jim
@mariuszmycz ; Just a hint; as i think you're maybe going to re-chrome the frame.
If so, then do check the fitment of the frame to your body first. I've got 8 frames and 7 of them are deformed due to overtightening of the nuts. this pulls the frame closer to the body, but the seal pushes the frame away from the body. As a result, the soft cast metal deforms a bit, giving a bit of a bend (kink) to the frame. Often the kink is most present at the inner mounting points.
I've sketched the deformation in the attached pic as an example:
I think, but haven't done it before, that the frames can be straightened.
Can anyone confirm that this is possible?
View attachment 197375 View attachment 197374
frames are pot metal or zamak,
very dificult+careful straightening
prone to break
Very unstalble, grainy material prone to crack. I might be even the bent frames are having micro cracks already (no visible as being hidden behind chrome/nickel/copper plating
