Removing the Wiper motor
Wobdog
a.k.a Mike
Los Altos Ca
I wanted to clean and paint behind the wiper motor, but was not sure if there was an easy way for me to remove it to clean and paint behind it. Before I did anything stupid I thought I would ask the forum. Step by step instructions , along with difficulty of project would be helpful
Mike
I just did this 2 weeks ago. It's not too bad.
From memory......
1. Remove wiper arms and disconnect electrics
2. Maybe pop off the drive arm from the rotating bit. Not sure if needed, but I did
3. Remove large nuts on top of paint below windshield. Entire mechanism can drop down once these are off so be careful.
There are multiple washers, bushings, and spacers in this stack so pay attention to order.
4. Roll out entire mechanism
Mike
Mike, if you only need access to area behind motor you can leave the wiper structure arms in their place
The motor hangs from a plate it is bolted to it with three hex headed bolts, also multiple plastic and metal washers
In this case you must remove the drive arm,
For an extensive cleaning of the whole mechanism it is good to remove everything as Thomas pointed out, no need to remove the drive arm in that case
If you disconnect the little rod in the motor, you should mark the position of it. Small center point or a mark on the shaft.
good tip - i did the same: the little notch on the axle points to the arm A. Arm B is also in line. This is how it functioned on my car without issue.
it's not difficult at all t remove the system. There are just 3 points: the 2 where it goes through the body with nuts + the rubber buffer where the motor rests on the body.
Once the 2 nuts are removed, and electrics disconnected, the whole system comes out.
One common failure point is the spindle on the triangle piece with the 2 ball joints and axle (Pin) that is located under the vent opening; because of the high water load, that axle is usually quite rusted inside the threaded sleeve.
rusted side (triangle) and the not-so rusted side (straight bar):
If you triangle piece is heavily rusted, a member of the german e9 forum is offering fantastically remade parts.
Warning: the while-you're-in-there risk is big here.....
I just realized it's a nice topic for a DIY thread - here ya go; it's in draft still:
I only need to move the motor to paint behind it. Can I just unscrew the 3 (marked screws) and the motor will drop down and I can slide it out? I just want to paint under it. Are the multiple washers the red circled area?
Mike, you unscrew the three blue ones plus the one in the middle, then you can unplug and remove the motor.
The red part is a rubber stop holding the motor in place, and can be left as is.
Did this zillions years ago, documented it with tons of pics, but you will get the glory,…you xmzkpyuuu !! !;-)
P.s. well done
Was SUPER easy to remove. THANK YOU. The advice about watching for the washers was spot on! Learning to take pictures and lable everything. By the time I get around to putting things back together my memory seems to be not as good as it used to be.
