EuroClassicMotors.com
Sold
honestly, it looks exactly like a transmission that was just taken out of a junkyard.
is there a warranty?
No it does not. S14/M30 are the same bell housing. Its a bolt on to M30 blockThe bell housing would have to be changed to fit the 6 cylinder, correct?
learned something new today. Thanks Anri! Have a spare for my M3. Maybe an optional home...No it does not. S14/M30 are the same bell housing. Its a bolt on to M30 block
Regards,
Anri
not it if it came out of an e30 m3. you can put the one out of your 4 speed into it.Speedo gear?
Thank you Anri.Hi,
Thanks for your reply.
In regards of Quote: "it looks exactly like a transmission that was just taken out of a junkyard"
I am showing the genuine original cosmetic condition of the gear box since 1990, re-seal will be required.
It has sweat spots. I can easily pressure wash it.
My customer drove the car for the passed 1.5 years, I personally drove the E30M3 as well and this
gear box does not have the typical issues if not maintain/driven properly...I rebuild these gear boxes
and major issues are: Whining on neutral(worn out input shaft gear mesh) , Popping from a gear while
driving(worn out fork), grinding (worn synchro), hard shifting(broken spring) none of those...Again, we
are going to custom gear box with custom ratios.
Yes I can provide Warranty on the gear box.
Thanks,
Anri
