Front wishbone torque settings
Socrates
Australia
Apologies if this has been answered before - would appreciate a second pair of eyes on the torque settings for the M16 and M14 nuts of the front wishbone as indicated below. I’m not 100% that I’m matching these correctly to the description on pg152 of Autobooks:
NmLb/ft
Front axel damper bottom 7655
Front axel damper top2317
Front axel damper threaded ring13094
Track rod on steering knuckle4633
Guide joint on track rod arm6043
Track control arm on axel support with normal load160116
Axel support on body7554
Tie bars with normal load6144
Can be torqued on the ground loaded with weight to achieve "normal position" with a bunch of extensions and some bracing to keep them in line. All a bit Heath Robinson but if you cant get it up on a 4 post lift it works. They're calling the wishbone 'control arm' in this list.
Thanks so much. In the meantime, I’ve also discovered these torque settings on pg 97 of this owner’s manual. Curious that none of them agree.
