Column with standard bolts, ign switch with regular key
Bavman
I have a couple of columns, can supply with goofy bolts replaced with standard, also have an ignition switch with regular, non Pebra key.
Just column with one way bolts removed, replaced with hex heads $100
Ignition switch $150
Both together $200
Includes shipping Cont US
[email protected]
Both together $200
[email protected]
Both together $200
[email protected]
Hi Bavman,
My ignition switch failed. It is always on as after starting engine, the engine remains running with turning key CCW and removing. Would your key/ignition switch fit a 73 3.OCSi (no telescopic steering column)? 2 keys with switch? Thanks.
Both together $200
[email protected]
Hi Bavman,
Please advise if the ignition switch with one regular key is still available. Would like to purchase if so. Thank you, Chris
ChrisMc - I've been doing business with Bavman for over ten years. He supplies vintage BMW parts across a wide varity of older BMW platforms and uses multiple forums.
He does not regularly peruse the forums, instead he puts his email address in his listings and expects people to use his email to express interest in the stuff he has. You need to use the email he posted in his original listing to contact him about this.
Thank you Ohmmess (like the name).
I’ve sent an email direct so hopefully hear soon.
Best
Chris Mc
