E9 A/C on-off, three position fan switch
You can look into this post
This assumes you use the internal resistor in the original evaporator box.
Other options are discussed here.
If you have a different blower motor in your AC evaporator box (eg one with built-in resistor on the motor and with separate wires for each speed), you would need a different switch.
Thanks, here's a photo of the one I'm looking for and the resistor is incorporated to the back of the switch.
see suggestions on replacement here:
https://e9coupe.com/forum/threads/fan-blower-switch.43867/post-385739
Alternative w/ built-in resistor:
Ebay Link
Amazon Link
there is also an option to buy a new switch for Mercedes that should fit into our plug, but it comes in a different price range than the aftermarket product:
I have one that I bought for my 70 2800CS but it was not the correct one for my car. I will compare it to your photo to see if it looks correct for your 73.
