I am restoring my harness, I replaced the broken and missing wires but I want to check if the old wires are working properly.
VERY good point!!I am a bit of a newbie/nitwit on electrical stuff, so I brought my harness to my PhD electrical dad who insisted to test the wires under load, so with a bright burning headlight bulb at the other end.
This way he explained, you can not only find a fully broken wire, but also identify when a wire has a significant bunch of broken strands.
You have to feel by hand if any connector and/or wire turns hot.
In my case we found a few broken wires, + a few spade connectors and earth points where the crimped wire partly separated at the crimp.
So the conductivity with a voltmeter showed perfect readings, but it got hot when loading it up.
( vibrations?)
Resistance testing it without the headlight bulb will show it conducts just fine: the few intact strands will be adequate for the low flow.
But when pumping higher volumes of current (amps? I always mix it up) through it, it'll get hot and burn.
YIKES!!!We use an extension cord with the outlet cut off and stripped to bare wire. 120v will show shorts and broken wires in 1 second.
Just watch for the smoke….
VERY good point!!
Power (measured in Watts) in an electrical circuit is the combination of current and resistance. Since the wires are not physically moving anything the power is dissipated as heat. The mathematical relationship is P=I^2R, where the I^2 means current (in Amperes) squared. R is the resistance in Ohms.
more difficult stuff
So the lamp will dim.
Always put the smoke back in…YIKES!!!
Probably best to not use that method when checking the gas gauge connection!!
This works, except most ohm meters are not super accurate down at low resistances, and many folks may use the "continuity" tester instead, which really can't differentiate these small resistances.Well, my take is slightly different, though the method is the same.
If you had 1/2 the number of strands damaged or removed, the wire resistance would double and the ohmmeter test would show that. After all resistance is constant vs. current in general for a wire.
You would see the best wires have resistance R and the bad ones 2R. You may see dimmer lights but I do not believe this would burn the wire as the increase in wire resistance would halve the current under high load, and the moment heat develops the wire resistance increases again further limiting the current.
The more realistic and problematic scenario is that you have half the strands at a specific pressure point. The reason the ohmmeter will not catch it is that the strands touch each other for the entire length of the wire, and thus continue to have the same parallel resistance with a tiny increase of the few mms where it is crimped. The problem is not that the wire resistance changed, it did not, the problem is high current density per strand at the crimped point. The current is not limited under load, so the heat develops locally at that small crimped point.
Net-net, you have to stress test it to find that type of problem, as Erik's father suggests.
