Mo Brighta
... white wire is high beam power (thick) or indicator (also white, but thin) to the instrument panel, usually a blue light. Fogs normally go OFF when high beams are ON, that is common.
OK, that makes sense. I was not sure how to read the fog lamp switch. I guess what happens is if the hi-beams are on, then both sides of the the fog lamp relay coil are hot, and so it is off. If the hi-beams are off, then the residual resistance of the hi beam filaments causes current to flow in the fog lamp relay coil, and the fog lamps come on. Kind of a weird approach, but I guess it works.... white wire is high beam power (thick) or indicator (also white, but thin) to the instrument panel, usually a blue light. Fogs normally go OFF when high beams are ON, that is common.
From the switch the wires are yellow/blue and grey. From the relay to the fog lamps they are yellow.Yeah, it's wonky but it works. The relay only takes 40 milliamps or so to work... high beams provide a workable ground path for the coil.
I think the fog light wires are grey/violet-- front - and rear fog too, if you have one. At least that's how they are in E24 and E28 cars.
Some seem the same. This is a 1974 car, which was a bit of a model refresh as I understandthanks for clarifying, seems E9 wire colors are different than the newer models... not surprising.
