Top Job by Just Dashes
coupesport
Newish Member
Chicagoland, IL
My adjustable steering column cover was trash and never did I see another for sale anywhere. I'm redoing the interior now and so contacted JustDashes with pictures of the piece and they said they could fix it. I was a bit skeptical, but see here the before and after >>
The other pieces look great also.
Does anyone know what they are currently charging for redoing the complete dash.
Just dashes re-covered my coupe dash did a great job and shipped with in a day of promised delivery date, seems like it was 5/6 months lead time and around twenty five hundred…
@halboyles and @boonies - By complete dash you may mean six pieces or just 3 pieces - My 3 piece Upper Dash Pad restoration was $2400 and they quoted separately the reconstruction/restoration/flocking for 3 other pieces: Steering Column Cover, Fuse Box, and Glove Box Door was $1300.
8 weeks was the lead-time. The glove box foam had delaminated quite a bit and you saw the steering column cover mess. Communication was excellent.
They have a good YouTube channel. I watched the shop tour and vacuum forming process and became more certain of the investment - and Vince's 20 year testimonial pleases me even more now.
@halboyles and @boonies - By complete dash you may mean six pieces or just 3 pieces - My 3 piece Upper Dash Pad restoration was $2400 and then quoted separately the reconstruction/restoration/flocking for 3 other pieces: Steering Column Cover, Fuse Box, and Glove Box Door was $1300.
Thank you for that information, very useful.
I guess it shouldn't be a big surprise but I paid $1200 for my three dash pieces in 2004. I sent all my wood pieces to Maderia Concepts at the same time, I think that was $1200 too. I had a new headliner (including sunroof panel) installed, Recaro front seats and door panels, rear seats all done in leather, new black vinyl on the tops of doors, and side console pieces all done for just under 5K. I did the whole disassembly and re-assembly of the dash and console. All of that for under $7500. It seemed like an absolute fortune at the time. Can't image what a complete interior would cost now.
edges not as crisp as OEM, but looks 1000% better
Is that an effect of the process they use?
I'm guessing shops like that will wrap your part with a new skin, on top of the old one. Thus increasing the radius of corners with the material thickness. Especially sharp corners will loose their "definition" , a 1 mm radius will become a ~2 mm radius, and that will look distinctively different.
Plus it think it also means the parts 'grow', possibly making for a tighter fit. That can be a good thing if the gaps were fairly large to begin with, but if the gaps were zero to start with, it'll be a pinch to get the part fitted nicely.
I recall comments here from Paul Cain that the dashes did indeed "grow" when recovered and required some trimming to fit.
