THANK YOU ALL for the feedback and insight. I will try to be more specific in my description.
I am a shade-tree mechanic, not a trained one by any stretch of the imagination. I am very mechanical and follow directions well. I've had my 2800 CS since 1981, at that time I did a complete motor rebuild and body restoration. Not off-frame but a pretty complete one. I rebuilt my 32\36's about 7 years ago because of hard starting. I took the carbs completely apart and cleaned everything very well. Before the carb rebuild, I had to pump the gas between 7 and 9 times on cold start, then had to ride the accelerator to keep it running (around 1500RPM) until it warmed up. Warm start was immediate. Idle has always been a little rough due to a higher performance cam. After the rebuild, I had to pump the gas only 2 to 4 times, but still need to ride the accelerator until it warms up. Once warm, it idles between 12 and 1400 RPM. My mechanic discovered many air leaks around the base of the carbs and the intake manifold. All of those gaskets have been replaced. There are no more air leaks. There may be a very slight leak around the shafts, but it is negligible and after the engine is warm is pretty much gone. I am in Denver and am not sure what the best jetting for altitude is? I do not know the numbers or sizes of the existing jets but will investigate further. If the air/fuel mixture screw has little or no effect, could it possibly be the jet before (above) the mixture screw? If yes, what size should that jet be? We have used a broad band O2 sensor. The mixture screw, after 2.5 or 3 turns has no effect on the O2 readings which are between 17 and 19. The mixture screw tips are clean. Air flow meter was at 5 (both barrels) for the rear carb and 4 for the front (on his meter). We couldn’t get any change or fluctuation on these values.
Now regarding the vacuum lines. I suspect that my mechanic MAY not have remembered or replaced the lines where they were originally. He is not an old coupe expert, but he is an expert mechanic. Should the vacuum line coming from the distributor be attached to the base of carb 2? Right now it is attached to the bottom of the air filter on the crankcase vent port, which, from previous feedback, I am told, supplies no vacuum. The line from the #2 carb is capped off. The vacuum port at the base of carb 1 is connected to the brake system. I have electronic points.
All feedback and questions are welcome!
