Off Gassing
BimRLuvR
Here's an interesting thing I am experiencing with my new to me Coupe: Off Gassing (no, not having a case of he farts LOL). As soon as I open my garage door, I can really smell the car. As I open the trunk or hood, its is VERY noticeable, and smelling the fumes gives me a headache pretty quickly. Even just sitting in the garage I can smell it. The interior has a distinct smell as well, though I think its new leather and maybe the sound deadening. This car was meticulously restored by Paul 5 years ago with 3 stage Glasurit paint and two coats of clear. Any one else experience this? And if you do/did, how did you remediate it? Thanks.
Five years after a restoration you should not be continuining to have off gassing from the materials used in the restoration. What does it smell like? Your use of the term fumes makes it sound like gasoline. If so, you have a leak somewhere.
Where was your car stored before you bought it? Does it smell moldy? If your car was stored somewhere humid prior to purchase, you may have mold in the leather. Peter Coomaraswamy restored a moldy car a few years ago. Took it entirely apart. Tons of work.
Hi there
Be very careful if it’s fuel that you can smell .
Some replacement fuel lines are very prone to cracking and leaking.
I would recommend getting the car up on a ramp / lift and getting every fuel line checked carefully.
As Barry sorta asked: what are you smelling? Fuel? Adhesive? Paint?
If it is strongest in the trunk and under the hood, then I would guess fuel. But it would be odd to have two fuel leaks, one at each end of the car. Carburetors allow a lot more fuel to evaporate than does fuel injection, but your profile says that you have a CSi, so that idea is out. The O ring that seals the fuel sender to the gas tank is a weak point; might yours be leaking? If the smell is fuel, is it stronger when the tank is close to full? It might be worthwhile to remove the trunk floor (an easy job) and inspect for leaks around the fuel sender.
Gas fumes and exhaust gas will give you a royal headache. I lost neurons to that.
Adhesive is fun and a recreational drug.
Some plastics and PVCs emit stuff when old.
Fuel has a very distinct smell. Is if fuel you smell?
Is it the same thing you smell when first coming in the garage, in the interior, when you raise the trunk or hood, or is it different smells in each case?
If not fuel, describe the smell.
Do you only smell it when the car is in the garage, or is the smell always with the car when the car is outside, driving, etc?
Can you smell the smell in the garage when the car is parked outside?
Thanks all. The car has been on a lift and been carefully inspected by VSR. Definitely not fuel. It smells like paint, and very dense paint at that. Especially noticeable in the trunk as I said. But its there under the bonnet as well. Even my wife noticed it. Its smelled like this since the day it was delivered to me. And i know, its a 5 year old resto, so why does it still smell so strongly? You would think the VOCs from the paint would be gone by now. If I drive the car with windows open, no problem. The interior smells like new leather, so it doesn't give me a headache. The paint off gassing , or whatever it is, sure does! Its possible I smell adhesive in the interior as Paul put loads of sound deadening in the there.
Dick: Only smell it in the garage when the car is parked there. When the car is out of the garage, the smell goes away. It is coming from the car, for sure.
Pretty strange to me!
Jim
As someone who has a wife who is sensitive to automotive smells, it may be worth investing in an ozone generator which you can order online for about $30 from the world's largest store (AKA Amazon). You don't want to be in the enclosed space while it's running, but it does do a nice job of negating smells. Run it for a few evenings in a row and see whether that helps. Not sure why you'd still have off-gassing years later, but if it's not fuel and instead seems to be paint/adhesive, this option may help clear it up.
This does not seem right. Yes paint will do this for a bit… not five years.
Keep the door open. It is more prevalent when you drive and then park? Or prolonged parking.
Thanks. Not fuel for sure. Read up on ozone generators and the reviews are amazing. One even said they had a stinky car in a garage this thing solved the problem. Worth a try!
