Newer one has an internal regulator. Are mounting bolt holes same size?
It's basically the same as the AC Delco CS-130.I hope this helps others:
The Bosch AL655N was a great replacement for the OEM alternator on my '72 3.0cs
So here is the question of the day - i have a new internally regulated alternator and since i have my wiring harness apart to redo the lighting as well as replace the red wire between the battery + alternator (significantly chewed up), now i know why i kept having electrical issues in the past ... and i am doing some suggested edits suggested from @sfdon ... i realized that my car still has the original wiring harness for the external voltage regulator. so i was going to keep the D+ blue wire in place, as it eventually runs to the program tester plug. i am probably going to leave the external voltage regulator off of the car, so i will probably run a new blue wire from the D+ alternator straight to the program tester connector ... so it continues the circuit to the red (battery charge) light on the dash gauge. does that make sense to everybody? if i do that, i could just eliminate that plug out of the harness and eliminate the black + brown wire between the alternator / voltage regulator harness ... i will add a ground wire between the alternator and the body.yes, bought an 85amp internally regulated one from BNR on eBay. It's been great for 4 years but just replaced it with another before driving to the Vintage, will keep the old one as a spare. Fits perfectly as it is rebuilt oem model. Run a D+ wire from new alternator to the D+ wire in the harness to the regulator. Tape off the other wires and keep the regulator in for orginality if desired.
that sounds like a reasonably good idea ... and it doesn't require running thru the harness.I just tapped into a +12v wire at the fuse box so it is fused.
New Bosch for it's price is an absolute no brainer.Looking at upgrading the alternator while changing the fan and viscous clutch, looks like a few options here. I reached out the BNRParts on Ebay, those tend to run about $500 vs the Bosch for $112 or a AC Delco for $120 or so. Any reason to spend the money on the BNR? Seems like folks have been happy with the Bosch or Delco. Also sounds like I'll have to fiddle a bit with getting screws to work depending on which one I choose but that seems easily surmountable.
