Got a couple of things to sort out. I have removed all the fuel injection system from the car in favour of triple webers with the 3.5 and 5 speed. I have 2 questions one relating to the fuel pump and one for the ignition
I have a wiring diagram that shows a black/red wire that goes from a pin on the starter and runs to the coil.
When the ignition is on i assume i should I get a 12v, is that correct as there is noting when I test on the pin on the starter
Is there a wire to feed the fuel pump as I can't find anything. Would it have been fed from the v ecu hence it no longer there. Nothing is shown for the fuel pump on my wiring diagram.
Any help would be much appreciated
