WTB - Vintage VDO Air/Fuel Ratio Gauge
I am not aware of an VDO AFR gauge; they do have exhaust temperature, but not AFR...
The best kit to recommend is the Innovate (LC-1) which could also feed a megasquirt :) But no vintage style for the gauge...
Edit: Ah, you may look for the MTX-L / -AL from Innovate :)
I haven't either but that doesn't mean much...worth a shot. Anyone like the Speedhut gauges? Good quality? And should I get a Lamda or regular analog AFG?
Speedhut makes great stuff. I just purchased a Stack white faced AFR kit for my S6 Avant since it has an unknown chiptune and no AFR gauge. Uses a Bosch sensor. I don't know of any AFR gauges that use an analog needle but it sure would be cool to have instead of the bright LEDs that all other gauges use.
The Speedhut gauges look great :)
I would recommend to get some information on the built in controller used (they are the central component in this type of gauge, as you know). As well as which probe to use - usually, a Bosch LSU 4.2 is used or its successor 4.9
Edit: seems like they use an AEM controller, sounds good :)
