My fuel pump is mounted on the frame rail under the voltage relay. The metal fuel filter is screwed into the inlet of the fuel pump.
I have removed the pump/filter and want to buy an inline filter I can mount where it is easier to inspect (transparent body) and replace on a yearly basis.
The plastic filters will work,but I would like to have one that can be mounted securely around the battery area, since my battery is in the trunk.
