Ok I have rebuilt my carbs, a project that when finished also included a new starter motor (because it was relatively easy to get to), all new hoses (even the little ones from carbs to block etc., as well as heater hoses as some were crunchy and easy to get to with the the manifolds off, cleaned and resprayed the engine block, stripped and sprayed the radiator overflow tank, resprayed the power steering resevoir cover, yanked the radiator and flushed and resprayed that, took the fan off and cleaned and repaired a crack in it, and polished the aluminum head a bit.  Some carb project!
Anyway here are my issues:
First off the rebuild kits come with the incorrect idle screws and choke plungers so I had to reuse those - I had to patch holes in the plunger diaphrams.....so i dont know if those parts are a factor in my problems.
The engine is difficult to start when cold and backfires through #1 carb. Once it starts it revs well but will not idle without stalling until it warms up. Not sure my accell pumps are working but they have new skirt gasket on them. I set the idle screws to about 1/2 a turn in after they start to move the throttle butterflies and the mixture screws are at 1 3/4 turns out. I left the choke adjustments/linkages alone from before the rebuild (except for the plunger adjustment), should I redo those from scratch or twist the choke covers counter clockwise (they are set at the notch now)? Should I increase the idle screws to help cold idle? Can anyone walk me through the choke setting procedure procedure better than the manuals do? How far shut should the chokes be on a cold engine with ambient air temp of 95 degrees? The rear choke is a beeotch to get to!
Once warm, the car will idle but every minute or so the car surges rpm for a few seconds then drops back again.
I guess to get me going in the right direction, what should my checklist be to:
a) solve the cold start issue
b) solve the surge issue (could this be a float setting or vacuum leak??)
Sorry for the rambling post and I appreciate any input. I hope these don't have to come back off but something tells me they might unless these are typical rebuild tweak items. At least my new starter works, it's getting a workout! Thanks.
