Ignition switch grenade
RichenFamous
Sacramento
Traced my intermittent ignition issues down since it finally gave up the ghost. Back of the switch popped off. Looks like it had issues prior and repaired so of course I attempted to repair it to make sure 100% this was the only issue. Apparently there were a few missing pieces (found a spring hidden in the CocoMat after putting it all back together). If one knew the spring location and contact plates orientation, you could bend the detents back with a pinch to hold it back. I ultimately ended up replacing the switch.
Got my yoga stretches in for sure, but happy to not have to jump the starter to get going. Made a nice jumper that I will keep in my emergency kit though!
Clumsy Ai, and funny for it as well: one arm turns into a leg, and one arm originates in his pelvis.
Though it does resemble how i feel sometimes. I'm currently drilling out the spotwelds of the metal plate under the dash that hold the hoodlatch. Same upside down yoga thing going on.
I agree on both counts, although I probably confused it because my prompt was to show a man contorting himself to do work under a BMW E9. It’s got enough problems with normal anatomy, asking for abnormal is too much for it. I do sometimes wish I had two right hands though.
