Hello everyone,
I am currently working on my engine and I am facing some issues with the triggering pins. I may have missed something, but I could not find any information on the forum…
Basically, when I switch-on the system:
I checked all the wirings and the harness. Everything looks ok (good continuity all along the wiring for all the pins). Fuel pump is powered and auxiliary injector opens when the system is switched-on (before starting).
When testing the pin 12, I have a resistance of 7 Ohms against ground. I understood that it should be direct to ground. Not sure if it is related or not. Pins 21 and 22 are showing an infinite resistance against ground (which makes sense).
Based on my understanding of how the D-Jetronic works, I have the feeling that I am facing an issue with my ECU. Can anyone confirm? Should I check something else on my system before sending the ECU for repair or opening it?
Thanks for the help!
Have a great day!
Side note: there are a lot of information on the forum on ECU/Injection, and it is not always easy to find (research by “ECU” or “control unit” provides a significant amount of results). Most of the case study, troubleshooting guides or conceptual data I could find are related to the surrounding equipment, but not to the ECU itself.
It may be good to have all the ECU/injection related topics listed into one single thread. What do you think?
Here below are some links I found helpful (not already listed in the forum published source):
SW-EM Bosch D-Jet Notes
fuel_injection_fault_tracing.pdf
- pin 21 is at 7V approximately and I can feel that injectors 2, 4 and 6 open.
- pin 22 is at 0V and at no time the injectors 1, 3 and 5 do not open.
- when I crank the starter, pin 21 voltage decreases slightly to 6V and pin 22 remains at 0V.
Have a great day!
