WTB: LC Wylie M30 bracket
e9Leveque
Looking to take the AC retrofit plunge so need the bracket for the Sanden compressor. This part is sold out currently on LC Wylie’s website. I sent a message to him here on the forum but no response, so I’m wondering if anyone purchased one of these and decided not to use it.
AC Solutions sells a Sanden compressor bracket for M30s.
As the shop is claiming it will fit M30 but also M20 motor to adopt the compressor maybe that one is worth investigating:
Interesting...I reached out to LC Wylie and will see what I hear back, especially given Scott's information above. If I download that printables file I could make the bracket it shows for about $100 in parts (cut to spec and deburred) which I would then have to weld and powder coat - both do-able but if there's already an option that works that would be ideal. But good to know there's a backup.
Local shop near me has used that bracket before. I already had ordered the parts printed and will try to weld them together in the next few days. Will let you know how it goes but yes, the one you linked works per their report
Looks like you still need the e28 wing cell bracket?
I have it! Has been vapor-honed.
Good morning. I am waiting for Layne to get back to me about one of his Sanden compressor brackets, and I'm getting to the point where I need to move forward with the job. Are there any good alternatives to his bracket? Have any of you used this one:
I would have a Wylie bracket ready to sell, the downside - it is in Europe and would incur tariff overhead
I used this on my son's e30 and it worked no problem. It's been on it for almost three years.
EDIT***Wait, no, we used the Wylie one..sorry, I know we looked at both.
If haven't found one yet have an extra of the old style one-piece aluminum mounting brackets for Sanden.
Direct bolt-on to block with slotted short arms for belt adjustment.
Mount spacing is for 3-belt crank hub pulley, and uses same four mount bolt locations as on big Bosch brackets.
(No, not the one saved for you, Doug)
Layne + Wylie ... same thing. the e30 one is different than the m30 one ... but they are great products
I installed the AC solutions and am very happy with it and I think it looks cool
Looks on the pic like the compressor is quite low to the ground (lower than the oil pan is).
Mud, water or even higher curb can reach the compressor front quite easily. IMHO not the best way to keep the compressor's long life operation.
For those who might be interested, by the end of next week we will have "2-in-1" brackets ready.
A single bracket that replaces both the original mount and the adapter, used for attaching the air conditioning compressor to the M30 engine.
This is a nice part because the only reason for us adding that large wing mount that bolts onto the side of the engine is to then be able to bolt on the Wylie or AC style bracket. I can see you have blended the two, having the Wylie style ends and an offset that recreates the relevant portion of the wing mount. Smart.
Yes, that’s exactly as you’ve described.
We scanned the original compressor bracket, the compressor itself, and a custom adapter made by another manufacturer.
Using software, we combined these components—incorporating some design refinements—while accounting for the mounting points on the engine block and the compressor attachment itself, including an adjustment mechanism for setting the V-belt tension.
