Unfortunate thing happened - my Zenith mixture screw turned fine up until today when i was making some post-pertronix adjustments.  The screw would not turn easily and felt like it was binding in the hole.  Turning it in or out did not improve it.  I managed to get the screw out and the bottom half of the threads are gone.  I installed the other screw to see if it was the screw or the seat that was bad - it's the seat because the other screw started to bind as it got about half way in so i backed it out.
Looks like I am in deep doo doo here - is it possible to replace the brass fitting that is pressed into the carb base? Any advice on this?
If not does anyone know of someone i can send the carb to for repair? Thanks.
