Headlight adjusting nuts
ScottAndrews
Petaluma, CA
I see there have been some threads on rebuilding the headlamp assemblies. Most of them are fairly old sat this point, but still useful.
Did anyone ever find a suitable source for the little plastic nut inserts that the adjusters screw into?
I see McMaster Carr sells something like this, but not quite an exact replacement.
Yes, not an exact replacement but an acceptable subscription as I used nylon insert nuts to rebuild my headlight assemblies.
Work fine.
The screws are M5-0.8 while the nylon nuts dims are around 9x9mm.
Don’t have the invoice readily available
Confirm that. I measured mine today. The lager flange is 12 x 12 and the body is 9 x 9. The hole is M5. The height is 14 mm, and the height from the top of the flange to the bottom of the barbs is 5mm.
Came across this short video on restoring headlights and thought “this is Scott, isn’t it?”
Nice attention to detail and end result is pretty nice
HAH!! Not me, but nice ellipsoid lamps!
I have recently re-discovered the virtues of the wire wheel.
Blasting is great on surfaces you plan to paint or powder coat, but it does not make for a good metal finish.
I recently disassembled my steering column, and wanted to clean up the lower steering shaft, which has lived a hard life in the engine bay. I was able to separate the rubber "guibo-like" coupler to remove the lower shaft. 5 minutes on the wire wheel and it looked brand new. Shiny and clean....
I blasted the metal lamp buckets after removing the zinc plated lamp holders, and plan to powder coat them today in my new Eastwood oven. I'll probably wire-wheel the zinc holders and then re-plate them
Looking good. The guy who made this video has a YouTube channel in which he details restoration on various parts of his E30. Lots of overlap with the E9, I may delve into these a bit - pedal box, calipers, brake booster, differential, etc. I don’t need to do all of that (some already done) but good to see how it is restored.
And post pictures of your resto - if I get the car painted this winter the headlights will be out, so might be the time to do this work. Hope you enjoy your powder coating oven, I think we are going to see lots of nicely done parts from you soon in addition to those we already have!
Scott, how did you remove these adjusters?
There appear to be two ways. The proper way is to carefully slide the bolts out of the retaining slot they are captured in. The wrong way is what I did. I use s needle nose plier to hold the retaining washer and backed out the screw until it came for from the nylon captive nut. We shall see if I can successfully put them back as they were...
I think on that video above the guy did your version, or at least it looks like he is unscrewing that bolt. Video is worth watching, David!
I'll definitely post photos of my headlamp restoration. I am going to powder coat the buckets, re-chrome the lens rings, and re-zinc the lens holders, so they should look pretty much new. I have a set of H1/H4 Euro lenses, so I'll be putting those in. It was a great satisfaction to toss the old sealed beams in the trash with prejudice!
Gents, Just starting down the path of changing and updating my 74' CSI I just brought in from Germany. First thing I did was change out all my headlights to the same H1 halogen bulb to make all the lens white. I then ordered new outside low beam lights, due to having one of them with water and corrosion. Added 4 new electrical buckets on the back of them. Lights are great, but while putting them back in, the rubber pieces on the retaining/adjustment screws broke off and I suspect a couple of the plastic nuts are starting to strip. My buckets look a little different from the ones in your pictures. The rubber pieces fit into square holes and tilt up. Have you got any replacement ideas for the rubber inserts or bolts? Is there a normal workaround? Thanks.
I assume you could find or make a plastic L shape hook with a M5 threaded up through it to hook into the side square hole to grab the tension. Then stick it through the housing and back up into the white nuts as normal? Just haven't seen anybody's idea for that. I will work on that fix. No big hurry. I think my headlights are back in tightly for now, but I still have to adjust the beams.
I ended up bending my bolts when I tried to pry them off the buckets. I drew this up in Fusion 360. I will try printing and report back.
