Question for you engine bay gurus regarding mystery switch
Catbert
Signal Hill, CA
Hi again everyone! I hope I haven't worn out my "welcome" yet as I'm only beginning to assess my newly acquired 1975 CSi. The wealth of information from all of the great members has already impressed!
This rotary switch lying above the passenger firewall and wired into a bundle along the AC lines has me stumped. Any ideas what this does and why it was installed?
As you may have guessed, that isn't the way the car left the factory, so we would be speculating a bit on exactly what it is / what it does. I would assume that it is a hack that replaced the rotary switch on the console that controls the A/C. Perhaps someone didn't want to go to the trouble of disassembling the console assembly to replace the original switch, or perhaps an original switch wasn't available, so that one was patched in. Does the rotary switch in the console now do anything?
The device lying on the cam cover (visible on the upper right corner of your first picture) illustrates that the car's previous owner took a casual attitude toward originality.
Thanks for your comment. I haven't even begun to check everything out even though the car had a comprehensive inspection prior to purchase. I was informed the AC is not working due to leaking hoses, so I am ready for that. This coming weekend I intend to push every button, turn every dial, and throw every switch.
Your observation about the electrical device lying haphazardly on the valve cover is duly noted. I'm not anal about originality, but I am anal about things beging done right. :cool:
From the general configuration it appears to be a thermostat. Why there no clue unless they stuck the sensor capillary tube down the heater fan hole or are using it for a secondary purpose. Does look like an R134a adapter on the AC hose coupler.
The item on your valve cover appears to be your windshield washer pump that belongs on the bottom of the windshield washer tank.
The item sticking out from under your blower fan cover appears to be a thermalcouple. It certainly doesn’t belong there. It belongs in the face of your AC panel HVAC panel inside the car.
  • Like
Reactions: Dlc
In general, you will need to follow the wires and see where they lead you. As with the comment about originality, prior owner(s) seem to have been pretty casual about color coding on their wiring, making diagnostics even more fun.
You also seem to be missing a drain hose - https://www.wallothnesch.com/en/hea...-2-5-cs-3-0-csl-e9/catalog-picture-64-03.html - these not only direct water, they help keep exhaust gases from entering the drivers compartment.
Doh! Yes. I removed it because my washer reservior is cracked and I need a new one. :rolleyes:
Keep in mind your model year AC wiring is different from earlier years.
No heater/AC changeover relay
Different blower switch
I forget why, but I removed my washer reservoir about 12 years ago and its still sitting on a shelf in the garage. I have yet to notice it missing.
Thanks, Dlc! I took the advice from another member and purchased the book "The Hack Mechanic Guide to Vintage AC", so I have that to pour over once I begin my AC component upgrade project.
there is plenty of threads on AC upgrades:
Maybe it needs a new home. ;)
I plan to drive my CSi often, so wipers with working washer nozzles is important.
Comments on a/c - you want the Sanden compressor, the largest condensor you can stuff into your car and a SPAL pusher fan in front of the condensor. (I have a SPAL pusher number 30102056).
Removing the AC faceplate is not that difficult. Removing the evaporator/blower or heater is an AWFUL job.
It is possible they wired in some kludge to adjust the blower speed. More likely they were either replacing or futzing with the AC switch. You can get to that by pulling the radio out, removing the AC face plate, and getting at the AC switches on the back side of that. If those white wires end up down in the AC, then you will either need to map out the circuit as currently built, or just cut all that crap out and rewire it according to the original plan. The latter would be my approach, since second guessing a long gone PO is a fools errand. Half the time the changes were made with a limited understanding of the system, and thus make no sense.
