Anyone know what size these threads are? I assumed they were pipe threads, but they are not 1/4 or 3/8th NPT. This is the vacuum source for the brake booster, right?
I would assume that these need to have some sort of barb fitting attached to them to connect the vacuum hose. What would be the proper sealant to use? Teflon tape?
I plan on using both a thread seler and a copper or aluminum sealing washer.I would assume that these need to have some sort of barb fitting attached to them to connect the vacuum hose. What would be the proper slant to use? Teflon tape?
If you plug it, where will you get the vacuum to power your power brakes?I'll hit the store in the next day or so to find a fitting for it. I'll be plugging mine, so I'll get the size soon.
