Hood Prop
Patton
Atlanta GA
BMachine asked for information on the stainless steel prop rod.
Summit Racing: Part number KTL-30523 at $46.95.
Easy to install. Drill a hole for the pivot ball, put the supplied plate over the “balled” end and you are done.
RP
(Gold piece at the top is off an e30.)
I own a CSi and want to install an auxilliary prop rod as a safety precaution. Can you post of picture showing how this rod folds into place? Thanks!
Check out the first photograph.
It rotates 90 degrees and lays next to the firewall on top of the little u-shaped bracket.
I hope this helps.
RP
I hope this helps.
RP
Good to know. Can you show a close-up of the bracket mod and how it stays attached to the hood? Thanks!
