Windows not working after interior removal
A few thoughts thoughts:
I doubt that your issue is a weak battery, bad voltage regulator, etc. If you have had the battery on a charger shortly before checking the windows, then I doubt that a lack of current from the battery is the issue.
If one or more interior panels are off, the first thing that I would check for is a bit of motion in the shaft coming out of the sardine can motors the moment the switch & relays are actuated. That white, serrated nylon coupler should rotate a bit if the motor is getting power. The typical problem with these windows is simply friction in the tracks preventing the weak sardine can motors from moving them. But admittedly, it is odd that all four are exhibiting the same symptom and that the more powerful, e28 motor also isn't moving its glass.
I hate to dispute what HB Chris wrote in post #2, but here's my experience: After I had my rear, outer armrests reupholstered, I couldn't bear to cut into them to reinstall the window switches, since no one ever rides back there. I just insulated the wire connectors and let them dangle. My rear windows still work fine using the switches on the console.
The more I read Steve's old posts, the more I realize that the windows are not wired in the typical way. He has a post from 2011 that describes how he installed relays attached to the battery https://e9coupe.com/forum/threads/electric-window-relay-upgrade.10435/
Unfortunately, as descriptive as that post is, it appears that he rewired everything a second time when he rebuilt the engine and cleaned up the engine bay - so it doesn't look anything like that anymore. I am having a hard time following the posts to understand where the wiring goes now, so, I sent him a text hoping to connect with him to get some insight.
Reading all those old posts, I certainly have a new-found appreciation for how fortunate I am to be the beneficiary of the incredible (OCD) work he put into the car!
Note that Steve didn't install relays at the battery; he just tapped power from the battery for the window motor circuit and added a blade-style fuseholder in that circuit (visible in the first photo in the thread that you reference above).
Note also that the relay wiring diagram in the first post in that thread applies to e28 motors, where you need to reverse the motor polarity to alternate between UP and DOWN operation. Sardine can motors are sort of two motors in one, with separate wires for UP and DOWN operation, so they use a different schematic.
Jay, my experience is with mid 73 window motors with circuit breakers and with these I had to have the rears connected. And if you have 12.1 volts with the motor running (ignition on is my assumption) that is too low, it should be close to 14 volts. Some of the wires may be swapped as the pre-73 coupes don’t have the bakelite plugs which makes it very simple. The Wiring Diagrams lists the terminal numbers and wiring color for each spade on the switch but they aren’t the easiest to read. I will look at the diagrams and see if I can write them down.
There is a pdf here from @rsporsche for the 2800 that you can download but should be the same and you can see Pin numbers and colors.
OK, here are switch terminal numbers and colors for the two rear seat switches and four console switches. Switch Numbers are from the US 2800CS and US 3.0CS Wiring Diagram with three wire sardine can motors up thru approximately Feb 1973 without circuit breakers. This has been added to the Wiring and Relays FAQ.
Armrest Switches
Switch 5, LH Rear: 30 Green, 32 Black/Red, 33 Green/Yellow
Switch 6, RH Rear: 30 Green/Brown, 32 Black/Red, 33 Green/Yellow
Console Switches
Switch 1, LH Front: 30 Green/Blue, 32 Black, 33 Green
Switch 3, RH Front: 30Green/Brown, 32 Black, 33 Green
Switch 2, LH Rear: 30 Green/Blue, 32 Black/Red, 33 Green/Yellow
Switch 4, RH Rear: 30 Green/Brown, 32 Black/Red, 33 Green/Yellow
I think I may be onto something. In a 2023 post, Steve referenced installing a “small ancillary fuse box on the firewall that powers the relays and windows”. He added that he was cleaning up the wiring so nothing would be attached to the battery terminal, and he installed the fuse box and routed window relays, stereo amplifier, lighting and other accessories through it.
I found this fuse box with the top 25A fuse blown. My hope is replacing the fuse solves my problem!
Armrest Switches
Thanks, Chris - that's super helpful.
The good news is that my RH Rear (switch 6) is connected exactly like that.
The puzzling part is that my LH Rear (switch 5) has terminals labeled 83Z, 83L, 83R and 83Y.
This is my LH rear. It's wired the same way as removed.
Hi there
Your before and after pictures look different to me.
I have marked the glue line in pink as a reference plane on your photos.
The switch male spade on one photo
seems to be parallel to the glue and on the other it seems to be 90 degrees to the glue.
Maybe the switch from one side of the car is different to the other side or something
It might be worth checking the connections against your photos again.
Armrest Switches
Console Switches
This post should be in the FAQs
Relays clicks because they receive proper "low" signal power (+/- ) from the switches that are feeded from oem car fusebox that seems ok in that case.
Probably there is no straight "high" power +12v to the relays/motors from the added/aftermarket wiring/fusebox straight from the ignition/battery (+), blown fuse might be the answer, but also grounding wire (-).
Check with multimeter each door relay pin 30 if there is straight +12v from the battery/ignition/aftermarket fusebox & also each relay/motor ground (-).
Maybe not the straight scheme, but might be partially similar
Thanks to everyone for the help and suggestions on this. I finally got everything sorted out.
I replaced the blown fuse in the custom fuse box on the firewall, only to have it blow again as soon as I reconnected the battery ground. That sent me on a wild goose chase trying to track down a short, which I eventually found.
It turns out the stereo amplifier had been spliced into the power supply for the windows, and there was a bad connection in that wiring. I removed the amplifier and cleaned up the wiring, and everything is now working properly.
I'll get around to reinstalling or replacing the amp someday, but for now I'm just happy to have all four windows working again!
I've also managed to get most of the interior back in. Just the door panels and front seats left to install. I'm having an issue with the seat recline mechanism, but I'll start a separate thread for that.
Thanks again to everyone who took the time to help!
  • Like
Reactions: Dlc
The high school dropout who wired the stereo in my car for the prior owner tapped into the number 1 fuse, which controls the running lights and blinkers on the left side of the car. He then removed the 5 amp fuse and replaced it with a 40 amp fuse. When the prior owner cranked up the tunes, it melted the light wiring behind the fuse block, at the front turn signal, and in the rear tail light assembly. I spent the first month I owned my car fixing this.
My car does not have a stereo now. I simply listen to the mellifluous sounds that emanate from the triple Webers.
