Could I please get a list of vehicles that would have the M90 engine? Some one claimed the 635csi used the M90 and someone else claimed the 7 series used the M90. I would like to find one in Michigan if possible.
You going to reveal your master plan here? Going for the engine upgrade? Something that maybe someday is in my future but other projects first!Could I please get a list of vehicles that would have the M90 engine? Some one claimed the 635csi used the M90 and someone else claimed the 7 series used the M90. I would like to find one in Michigan if possible.
Exactly my plan. I am upgrading to megasquirt in a manner that allows future engine upgrade but given that I have a csi I’m figuring that change alone along with the longer ctubes may give me all the pizazz I need. If at some point the engine needs a rebuild maybe that’s when I decide on a swap.
The idea of lengthening the stroke on the M90 is interesting. The stroke of the M90 is only 84 mm. The stroke of the M30B35 is 86 mm, and the stroke of the S38B38 is 89 mm.For me the choice was roughly thesame.
After opening my engine, it turned out it needed everything. And if i was going to spend 10k on an engine rebuild, i opted to start with a m90 block. In my case the cost delta was just in the m90 block vs an tired m30 block. New custom pistons are same price, regardless if they are for m90 or m30.
I do use the longer stroke crackshaft, not the m90's, increasing piston throw a few mm's.
Not all E12 based 635's had the CR gearbox. My 1980 635 was bone stock, and has an M90, 256/6 overdrive gearbox, and 3.07 diff. It is VERY long legged... I suspect they made them that way for Autobhan cruising...There are a few less than perfect 635s around, hardly any 735s ( not sexy enough to import back in the day unless a SA 745). E 12s are pretty much all accounted for in the States and to cannibalize one of those would require some soul searching. Another thing to consider is they all are attached to a Getrag CR gearbox, even the E23s, I believe.
And stroke of the 3.3L was 88.4mm. Not as expensive as the S38B38 crankshaft, but similarly hard to findThe stroke of the M90 is only 84 mm. The stroke of the M30B35 is 86 mm, and the stroke of the S38B38 is 89 mm.
Ahh that clears up some fog in my brain. I had in my mind that the normal M30s used an 89 mm crank.. AI let me astray!And stroke of the 3.3L was 88.4mm. Not as expensive as the S38B38 crankshaft, but similarly hard to find![]()
I think that was Mike Berger who did the B38 crank whilts building a 3.8CS, and he found a new one in Germany. Mike talks about his build in this thread: https://e9coupe.com/forum/threads/bmw-m90-questions.40073/post-347520The idea of lengthening the stroke on the M90 is interesting. The stroke of the M90 is only 84 mm. The stroke of the M30B35 is 86 mm, and the stroke of the S38B38 is 89 mm.
So if you can find a B38 crank, you can get 3.8 liters out of it. IIRC @paul cain did this in his 3.8 CS coupe project. But, 3.6 is probably easier, and should provide plenty of juice...
