VARA BBB Sun Race Grp3 Essex 1970 2800CS
Yes, track is Willow Springs from last weekend. The year end "Big Bore Bash" race for VARA. Apparently the Goodwood Festival is coming to Willow Springs next year and new owners (Singer and a private equity group) are already updating facility. Definately looking better. Talk of adding "chicane" on the back straight to slow down the modern super cars but they will keep the option of original layout too for clubs that want to run it.
I love the idea of adding facilities and modernizing a bit, but I fear that they won't keep it nearly as accessible as it has been for so many years.
Thanks Markos,
For many years I ran a Getrag 265/6 Overdrive transmission with my car (rear diff is a 3.90 LSD) but I found the gap between 2nd and 3rd was too big and I would drop out of the powerband between those gears. Had great top speed though for long tracks like Cal Speedway and Willow Springs. For most tracks I rarely dropped down to 2nd but when I did and then shifted up to 3rd gear I would drop way below my powerband. Nothing wrong with a 265/6 OD transmission for most tracks (at least if you are running a 316 or smaller cam and have typical M30 torque available).
Then 2-3 years ago I switched to a Getrag 265/5 Close Ratio transmission with the dog-leg pattern. Gap between 2nd and 3rd is gone and gears are closer but my top speed has dropped a bit (5th is now 1:1 where before 4th was 1:1). In the video you can see that I max out at 7K rpms (my conservative redline) early down the front straight just before the start/finish line (last lap my tach started acting up, disregard that one). Still learning the new-to-me dog leg shift pattern and even harder, is me trying to adapt to the new places I now have to shift on track. Slowing getting there but hard to forget all my previous shift areas on the track. This is my 3rd race at WS with the Close Ratio. I really like the closer spacing of the gears on the Close Ration box. More than likely, I will change the rear diff out for longer tracks in the future.
I still want to try a ZF S 5-18/3 Close Ratio transmission but those are so rare (and expensive) to come by in the US. As a side project, I have a couple stock ZF 4spd transmissions that I am experimenting with on trying to convert to 4spd Close Ratio transmissions but have put on hold until after some other projects.
@Clubsport_CSi
was going to say, "hey, but you have the Nurburgring" but they are complete opposites in high speed tracks. Maybe the old AVUS track in Berlin would have been the most similar to Willow Springs? (other than the banking)
Thanks Markos,
Wow great info. If you want to really experiment on a ZF I have a S5-18/3 out of a maserati, plus the basic parts list on how to build. It needs new CR gears. But you can take the front case from the 4spd and the tail housing and bolt it to the center. Need new selector shafts and housing and a bunch of other parts. Still not cheap but far less than a freshly rebuilt motorsport one. Anyway DM me I got it for pretty cheap, and I need to be realistic about my e9 endeavors. I still have a 4spd ZF and a G265/5.
There are some good videos on the ZF breakdown on youtube and every component is still available new. Lots of aftermarket gears also but you need to buy the whole set as they aren’t compatible with ZF factory gears.
Not sure if they also plan to have Porsche Experience Center there (as published on Porsche Talk)?
Would be great opportunity for sure!
I did a track experience on the Tilke track in Leipzig in a 992.2 Carrera S and at PEC Hockenheim in a 992.2 Carrera 4S - great bang for the buck :) !
And if you push it through the track - these downshifts with the PDK in Sport Plus when braking into curves in combination with the factory sport exhaust package ; and the engine screaming in your back when accelarating on the straight!
That car is incredibly capable on the track; easy to handle even for an idiot like me. And they driving them 100+ laps over a regular training day without any issues...
Thanks for the ZF leads/offers Markos and Keshav. Transmission change to a ZF unit is on the back burner for me now that I have the CR Getrag in but I will definately follow up when I get into the ZF 5spd red mist again. I also really want to try and assemble a ZF CR 4spd from mostly stock parts. Would be great to use and repurpose something that almost everyone is tossing away.
992.2 Carrera sounds like great one.
@Shawn Essex
Shawn, I remember I read a bit about your very special car - but are there any details to be found about your door construction? On the pics from the video it looks like they are rather door skins only?
And how do you maintain the engine during races? Regular changes of bearings etc. or does the M30 perform just as is?
Thanks in advance!
I remember once coming across a photo of your car with the hood open...
I can't find it now, but I remember my jaw dropping in amazement.
This car has the look of a rugged, racing-bred thug...
The wheels on this car are a bullseye.
Your racing toy is truly one of a kind.
A small, personal request from my side.
You should take part in the contest I’ve organized.
It would be great to see a photo of your car in an interesting location—like a racetrack, for instance.
I know you don’t have any use for air conditioning in a race car, but as an incentive, I can tell you that one of the prizes is a set of racing mirrors.
Personally, I’d love to have a calendar featuring a photo of your car for one of the months...
@Clubsport_CSi​
Attached are pics of my door construction. You are correct, they are just fiberglass skins that have been reinforced (to prevent sagging/flexing). Went this direction to lose weight and also for quick removal (car weighs 2,354lbs). Driver's side swings on 2 pivots and passenger door is attached via 4 shaft collars. You can also see the trunk is also fiberglass and strengthened with some steel straps my brother Shad fiberglassed in. I was very influenced by the Broadspeed car and also the DeKon Monza builds. Really wanted a race car that as I got older it would be easier to maintain and have good access. Did Dzus fasteners on removable nose of car, doors, trunk, air dam and rear fenders for easy removal.
As far as maintaining engine during a race weekend, it usually is just watching temps (add oil or water if needed...very rare), 4-5 gallons of 110 leaded race fuel per 30min sprint session and all the other normal prep (torque wheel lugs to 80lbs, air pressure set 25-26lbs per tire, etc.). Before each race weekend the car usually gets full oil and filter change (11 quarts-straight 30wt...car has a 3 quart oil cooler and a 3 quart Accusump), new spark plugs. Every 3rd to 4th event new cap and rotor. Motor was built by Terry Tinney in Livermore, CA back in 2005. Head has since been refreshed by Antony Rodino in Duarte, CA in 2025.
Motor specs: M30b35, 12 to 1 compression, 316 Elgin cam, Hardened steel rocker arms, knife edge crank, Weber triple 45DCOE carbs, etc
When fresh back in 2005 car made 269rwhp. Now with over 20+ years on the bottom end and the refreshed head it dyno'd at 256rwhp last year. Very happy with my M30 motor!
@[B]Lucas[/B]
Here are some pics (some with nose tilted open).
I like the pic you chose in your thread, feel free to use for a calendar as long as you keep photographer's stamp in pic (if it has one).
Wheels were meant to be temporary while car was being sorted but the trans am style wheels have grown on me. I really want to end up with gold BBS e50 or e55 rims but for now I am pleased with the Trans Am Engineering wheels. And at $250 ea, can't beat the bargain. Note: the white faced gauges were also supposed to be temporary while initially sorting the car but when I review my in car footage after races, the white faces really help me see better what is going on with motor....still on fence if I eventually change out for black face gauges.
