M90 source
D Calkins
Royal Oak, Mi & Montgomery TX
Could I please get a list of vehicles that would have the M90 engine? Some one claimed the 635csi used the M90 and someone else claimed the 7 series used the M90. I would like to find one in Michigan if possible.
Lucas' list is a good one, but if you are looking for a car in Michigan, be advised that only the European versions of the cars Lucas listed have the M90 engine. In the US, the M30b34 and (after around 1988) M30b35 were the engines found in the 535i, 635i and 735i.
You need to find a late 1970s or very early 1980s European model M535i, 635csi or 735i. Of these, the most likely candidate is a 1978 through 1982 635csi.
The EURO M90 block has the higher compression 9:3:1 compression. So you may need to look in Europe to find one, or maybe luck out with a USA supplier who has a Euro block for you. Hope this helps!
i would check with @sfdon ... he usually has a good handle on the availability. also one of the best around with engine builds + injection ... but he is very busy
All of the pre 82 635’s were Euro cars. The US version E24 until 82 was the 633. The 71-82 unit was Motronic. Pre 81 was L-Jet. There were quite a few that were imported as grey market cars
You going to reveal your master plan here? Going for the engine upgrade? Something that maybe someday is in my future but other projects first!
i recommend driving a coupe with what you have for a while before going for the significant engine upgrade. there's a lot to love about the stock m30 3.0 ... especially the CSi (if you have one). with the CSi compression, if you made the change to megasquirt or just replaced some of the tricky (hard to get) d-jet parts ... you still have a lovely engine that winds up quickly. a cam would liven things up a bit.
Exactly my plan. I am upgrading to megasquirt in a manner that allows future engine upgrade but given that I have a csi I’m figuring that change alone along with the longer ctubes may give me all the pizazz I need. If at some point the engine needs a rebuild maybe that’s when I decide on a swap.
For me the choice was roughly thesame.
After opening my engine, it turned out it needed everything. And if i was going to spend 10k on an engine rebuild, i opted to start with a m90 block. In my case the cost delta was just in the m90 block vs an tired m30 block. New custom pistons are same price, regardless if they are for m90 or m30.
I do use the longer stroke crackshaft, not the m90's, increasing piston throw a few mm's.
There are a few less than perfect 635s around, hardly any 735s ( not sexy enough to import back in the day unless a SA 745). E 12s are pretty much all accounted for in the States and to cannibalize one of those would require some soul searching. Another thing to consider is they all are attached to a Getrag CR gearbox, even the E23s, I believe.
The idea of lengthening the stroke on the M90 is interesting. The stroke of the M90 is only 84 mm. The stroke of the M30B35 is 86 mm, and the stroke of the S38B38 is 89 mm.
So if you can find a B38 crank, you can get 3.8 liters out of it. IIRC @paul cain did this in his 3.8 CS coupe project. But, 3.6 is probably easier, and should provide plenty of juice...
Not all E12 based 635's had the CR gearbox. My 1980 635 was bone stock, and has an M90, 256/6 overdrive gearbox, and 3.07 diff. It is VERY long legged... I suspect they made them that way for Autobhan cruising...
I think that was Mike Berger who did the B38 crank whilts building a 3.8CS, and he found a new one in Germany. Mike talks about his build in this thread: https://e9coupe.com/forum/threads/bmw-m90-questions.40073/post-347520
Well, if you are looking outside Michigan, I have two suggestions. First, I know @Bejoe16 had more than one M90 last year when I bought some stuff from him. You might reach out to him and see if he has one he would sell. Joseph is in Georgia.
Second, when seeking hard to find old BMW parts, its always useful to try Al Taylor. Al is located in North Carolina. I've bought a bunch of parts from him. He goes by Bavman here, but you can't just message him. You need to use his email - [email protected]
