Door Brake Assembly - Fix for Door that Won't Stay Open? Where to Buy?
Catbert
"Nothing happens until something moves."
Signal Hill, CA
Hi everyone! Another "fix it" discovery is my passenger door that won't stay in an open position. A little research leads to a faulty or worn door brake. Some have mentioned a site "OEM???" I should go to for parts, but I don't remember the exact name. So, a couple of quick questions. Is the door brake the 99% fix factor to address a door that won't stay open as I suspect it is? Second, where is a good place to buy the right part (part #51210301600)? Thanks!
Some info here.
i have two of that style (new) that i bought a while back. this works with all of the standard mounting stuff. you can use the mercedes stop, you will just have to put a filler tube in the arm so the pin fits tightly
I installed the MB part in Sixto and I think it is superior to the BMW OEM part. It fit perfectly and I don’t recall any pin issues. I have a set at home I’m going to install in Sahara and when I do it’s used brakes will be available.
Regards, Jon
the pin is too loose in the bar of the MB piece. i put a piece of the blue hose (from the fuel evap system) and reamed it out a little bit and the pins went in just fine. i used the new BMW pins. i have the MB brake in my coupe and i installed them earlier in the year so the memory is still fresh.
I went the MB route and got some filler/shim (gas tank vent hose) from SFDon. Although the original stop has failed for most of us, it is probably based on use when the car was a daily driver so I suspect at this point in time, using new OEM if you want, will last.
Regards, Jon
Hi Jon. Since I'll be going through the trouble of removing the door panel to install a door stop, I feel better about installing a new vs. used part. Thanks just the same.
I installed the MB Part #126 720 05 16 and it makes a click when I fully open the door. Will the correct pin fix this?
I ordered a new door stop from BMW of South Atlanta along with a replacement rivet or pin as was suggested. Since this job entails removal of the door panel, I also purchased a supply of the plastic fasteners that BMW uses widely in many models over the years. I purchased 20 on Amazon for only $8.99.
51-21-0-301-600Door Brake C415021$112.371$112.37
51-21-6-650-054Rivet C519590$7.471$7.47
I have used a 4mm bolt (I think) and had to use a bit of plastic tube, just a small slice, to shim it. Same if you use the original pin which is usually beat up or even bent.
If that pin moves, over time it will fish mouth the support and cause the clicking problem to worsen. I have this now on the E21 I just bought. This must be an issue on the 2002's since I found a company that actually makes a fix/replacement for the door stop supports. Interesting solution.
BMW 2002s have the same problem. Harry Davis makes replacements; I believe, starting with a Mercedes part and then modifies them.
I have heard that they are better than original. Anyhow, I ordered a set and expect to receive them the end of next week.
Here is his email address: [email protected]
