Bmw e9 complete body harness
bavarian
From headlights to tail lights and everything in between , it is unlabeled but it should all be there there could be a few random small universal connectors needed but all the big plastic ones seem to be there , removed my self From a 3.0cs , wires seem nice and flexible
300$ plus shipping US only
I’m interested depending on the year not looking for a 74. I’m not looking for a 2800 looking for US version.
Is there any difference in them or if how how could I tell one was a 72 I have two harnesses total
74 has a low beam relay under the dash so you could find that plug with a Yellow wire near the other electric window and load shed relays. Some of the wires are a thicker gauge and the headlights may have a tracer color that earlier coupes did not have, fuses are in different locations on the fuse block as well.
Does it have six bakelite plugs for window motor switches which appeared in Feb 1973? That might be the easiest clue.
looks like a euro car where the blue wires don't go to the turn signals, they go to the city lights in the low beam. that being said, there are 3 wires to low beam (which is h4) and the high beam connector between the low and high lights ... which says USA
Maybe could use that harness at the moment! Have fun with the wiring / do positive and negative run in reverse down under?
