Getrag 262 (4-speed) transmission crossmember / mount fitment issue on my CSi
LEO
BOGOTA COLOMBIA
Hi everyone,
Before 2026 wraps up—and so I don't end the year without making progress on the project—we are finally installing the 4-speed Getrag 262 transmission in my CSi. However, we've run into a few fitment issues.
When we disassembled the car about 6 years ago, we noticed the transmission crossmember/bracket that came with it looked a bit strange, wasn't in great shape, and didn't seem original. Because of that, I ordered a replacement off eBay back in 2024 (shown in the attached photo). Now that we're test-fitting everything, we realized this eBay bracket is way too flat and doesn't line up properly.
Could you guys offer some advice on:
  • Any suggestions on how to solve this or adapt it properly?
  • The correct OEM part number I should be looking for?
  • What specific measurements or clearances should we check to avoid any alignment or stress issues on the chassis/tunnel?
  • Whether any crossmembers from newer BMW models (which I've seen around) will work with the 4-speed transmission?
Also, if anyone happens to have photos of an original crossmember installed (or off the car) for reference—or even has one for sale that might work for me—please let me know!
Any tips are greatly appreciated! As always, apologies if this has already been covered on the forum, though from everything I've searched and read so far, it didn't seem like a topic that's been discussed in detail.
Thanks in advance!
Thanks for the link and for confirming the part number! I actually always make sure to check RealOEM first before ordering parts, which is why I went with that one—and why I’m even more confused now!
If the part I bought is indeed the correct 23711101810 bracket, why isn't it lining up properly during test-fitting?
If you look at the photo of the old bracket I removed 6 years ago, it is heavily bent/angled—at first I thought it was damaged or hacked together by a previous owner, yet when I look at other reference photos online, I actually see similar curves/drops on some crossmembers.
What could be going on here? Could the problem be:
• Engine/transmission mounts sitting too high or too low?
• The chassis mounting tabs on the tunnel being bent or slightly off?
• Or maybe there’s a spacer, specific rubber mount height, or orientation (flipped front-to-back) that I’m missing?
Any insight on what to check next would be hugely appreciated!
The picture doesn’t look anything at all like a four speed Tranny mount
  • Like
Reactions: LEO
Nothing in your first picture looks correct
The Rusty item has nothing to do with the Coupe
The second picture is correct for a four speed transmission support and matches the two that I just posted
  • Like
Reactions: LEO
Please post a picture of your rubber motor mounts to the engine
  • Like
Reactions: LEO
OK
And the picture of the actual tranny support you are trying to use please?
Chris will explain this pic- i’m running into a meeting
  • Like
Reactions: LEO
What Don means is the passenger side body mount is higher than the driver side. The crossmember support is also higher on passenger side. Put the rubber support onto the crossmember and it should line up perfectly
That is correct, rubber bushing goes on passenger side under the flange on the trans. Trans won’t lift any higher? The key will be if the trans support lines up with the bolts on the body, some modify that support with an added flange to keep the bolts in their slots.
I’m currently working on the driveshaft / center support bearing assembly on my 1975 E9 and wanted to double-check a couple of details with the experts here before ordering parts (referring to the attached parts diagram):
1. Threaded clamping ring (26117514037) vs. Tooth washer (26111100692 / #14):
In the older parts diagram, items #13 (threaded ring), #14 (tooth washer 26111100692), and #15 (compression sleeve/bushing) are shown as three separate pieces, with the tooth washer (#14) sitting right between #13 and #15.
If I buy the superseded modern part 26117514037 (threaded ring with clamp-ring), does it replace the whole #13/#14/#15 setup on its own, or do I still need to source the tooth washer 26111100692 (#14) separately?
2. Item #10 on 1975 models:
Does a 1975 model actually use item #10 shown in the diagram, or was that piece only used on earlier production years?
Thanks in advance for any insight or experience with this setup!
