1971 2800CSA: Turn Signals & Hazards not working
@sfdon believes my problem may be the wrong turn signal assembly for a Euro-spec car. I removed the steering column lower plastic cover and inspected the wiring bundle. While it all looks stock with no signs of being replaced or repaired, @sfdon says the wrong turn signal assembly may be the problem. I don't understand how this is possible as I would expect to see signs of a new turn signal assembly being installed. But as the Zen Master says, "We'll see."
My poor car has been rendered undriveable by little things since it arrived. Yes, it currently runs, but driving without turn signals is like driving without a seatbelt... not for me.
Catbert -- I understand you, here is a small anecdote for you:
When I bought my E9 in 2018 in Germany, I drove it home to Austria on its own wheels. Germany did not require seat belts for vintage cars, so I made the trip across the Autobahn (going up 90 mph) w/o any belts .... it felt strange, but I was so geared up by my "new car" that I forgot after a while about the missing belts and what could happen in case of hard breaking/accident a.s.o.
Fast forward a couple of years, post-restauration - whilst driving, my indicatior stopped working at one point. I fixed it later on when coming home, but with 50+ yrs old cars, things happen - always - not a question of if but when. I learned a great deal of resilience, patience and stamina over the last years, along with a "can-do" attitude.. as this is my first car I am working on
Been there man! And I know you want to take it for a drive since you've been waiting for it for a while, but take this opportunity to open the Pandora's box of other things that might need doing while you're waiting to figure this out...
Yes, I am. I have already addressed and fixed a number of nagging things (oil filter bits thrown out by mistake, hood torsion bar broken bracket housing, stripped threads on engine oil drain plug and differential fill plug, stripped threads on one brake bleeder screw, and cracked washer reservoir. Still on my "to do" list besides the turn signals are replacing one worn door stop, replacing missing door weather stripping, adjusting the valves, replacing the inline fuel filter, and figuring out how to wire the driving lights I installed on my new bumper. The green light switch below the two fuse buttons on the dash is wired to something, which I was told is for fog or driving lights. There are none other than what I installed. It would sure be convenient to use a switch already installed and wired.
I hear you and feel you. I'm not frustrated. I've been working on cars for many years. I'm just anxious and so looking forward to fixing the key items that prevent safe driving. I still have plenty to do with the car to keep busy as I just shared with @e9Leveque. :)
  • Like
Reactions: Dlc
Yes, the green switch is wired for fog light but I think that often is going to the rear for the rear red fog light. Rather than using that button and wiring it for the fronts, I removed my cigarette lighter and installed an E9 knob attached to a two-position switch. I have mine, like you, as somewhat of driving lights rather than fog lights so I wanted a way to have an easy on/off without having to reach under the steering column for the green button. Happy to send a pic of the end result.
Ah! That makes sense about the rear fog light. Now I know how to turn it off. Using the cigarette lighter switch for driving lights is a great idea. Yes, please post pic and where/how you mounted the relay.
What Dic said!
  • Like
Reactions: Dlc
Here are pics of my shifter console. In place of the cigarette lighter is a 2-position pull switch. This might be from a 2002, since I don’t think the e9 has any 2-position (off/on), only three position - lights, wiper, etc. I used the decals available from Mo Faraz here on the forum to identify wipers and lights.
This makes total sense, especially if those switches are often on the opposite sides from US to euro. Also All those wires that go up to those two switches could easily be interchange incorrectly and finally if for example Don had changed the switches, you would never know.they wouldn’t look like they had been replaced compared to some hack jobs. You might see
new paragraph
is that funny?
