dj_efk
Guys now that I've finally got my coupe (March 69 2800cs) back on the road doing shakedown runs, I hope you don't mind me posting each of the inevitable gremlins that are inevitably cropping up
So my fuel gauge is playing up: after brimming the tank and doing 180 miles it still reads more than 3/4 full, it also dances around fairly violently when the car is in motion, plus the low fuel lamp is permanently on!
Is the fuel lamp powered from the same sender as the gauge itself or is there a separate sensor?
I haven't checked the gauge yet but in my experience fuel gauges either work or they don't at all, so I'm assuming the problem(s) to be either with the voltage stabiliser (if there is one, where is it and how would you check it with a multimeter?), or with the sender unit itself (ditto?)
All opinions greatfully received!
